No output from analog power supply
priyanshugahlaut
Joined Oct 29, 2025
I'm not able to get ±120V from the top power supply unit.
Any suggestions regarding power supply unit or the full circuit would be appreciated.
meth
Joined May 21, 2016
314
Well... for start you can try measuring where the 120V are lost? After the bridge, before the TL.. after the TL.. ?
priyanshugahlaut
Joined Oct 29, 2025
I'm getting voltage after the bridge, on the capacitor, even before the TL (for positive only, not for the negative) but not after the TL
DickCappels
Joined Aug 21, 2008
10,661
Change U2 to an LM337-T.
The problem with having an LM783 is that it is a positive voltage regulator which can only pull the output down toward the positive-power supply.
An LM337 is intended as a negative regulator which can pull the output toward the negative power supply. That's what you need there.
