Oscilloscope Loading
Biomed27
Joined Jan 30, 2015
9
The vertical amplifier of most oscilloscopes typically has an input resistance of 1MOhm and a calibration accuracy of 3% of full screen deflection. You want to use a scope to measure voltages in a variety of circuits yet limit loading by the scope to 3%. What is the highest output resistance of the circuits that you wish to measure that will remain within this load limit?
I originally thought I could solve the problem by setting up a voltage divider solving for R1 and R2 for example. Upon writing some equations down I ended up with an R^2 term thus a nonlinear relationship and I decided I am making things too complicated. Maybe I don't fully understand the question.
Does anyone have any suggestions?
38,777
Yes it's a simple voltage divider problem, so you determine what resistance in series with the 1 Mohm input will reduce the voltage by 3%.
Of course, worst-case, that can give an overall error in the measurement of 6%. Personally I would want to limit the loading error to less than 1% to maximize the overall accuracy.
35,138
Work backwards. You want to limit the error to 3%.
What value of R can you put in parallel with 1MΩ that will result in an equivalent resistance of 0.97R?
Biomed27
Joined Jan 30, 2015
9
I calculated about 32MOhm . . . But that doesn't seem right? If I set the parallel combination of 1MOhm and R equal to 0.97x1MOhm, thats the result I get for R . . .
35,138
Try again. You made a mistake somewhere.
Think about it.
1MΩ in parallel with 1MΩ would be 500KΩ.
1MΩ in parallel with 10kΩ would be close to 10kΩ to within 1%.
Biomed27
Joined Jan 30, 2015
9
Ok, I think I was misinterpretting the problem. Instead of setting the parallel combo equal to 970k I wanted to set it to 3% of 1MOhm = 30K, in this case using the 1Mohm value given and the calculating the value of the circuit resistance I end up with about 30kOhm, which makes much more sense because in that case the circuit resistance is much less than the oscilloscope therefore the oscilloscope will have a small loading effect.
Thank you!
35,138
You got it!
Now you can see how you can estimate this in your head.
10kΩ would be accurate to 1% with a 1MΩ scope probe.
20kΩ would be accurate to about 2%.
30kΩ would be accurate to about 3%.
Note that is approximate. It goes out of kilter as you go higher.
