Hello guys, how are you? I have recently started learning about electronics from the "Make: Electronics" book by Charles Platt and using the text books published on this very website. Following circuit is for the oscillator that can be used to produce a beeping sound, or in my particular case, flash an LED in a 1s interval.
It works perfectly on the breadboard but for some reason it failed when I attempted to make it on a single hole PCB board - the LED becomes lit but doesn't flash. Following images are from the said PCB board, and while I don't expect a direct answer (it doesn't work because of this and that) I would very much appreciate a hint - as vague as it is possible.
The last 220μF capacitor was added (but wasn't wired) to dim the LED gradually - hence the 2x 470Ω resistors instead one 1k.
Any suggestion and constructive criticism is also welcomed, thanks in advance!
