Oscillator Circuit Issue
Đorđe Jocić
Joined Aug 15, 2019
14
Hello guys, how are you? I have recently started learning about electronics from the "Make: Electronics" book by Charles Platt and using the text books published on this very website. Following circuit is for the oscillator that can be used to produce a beeping sound, or in my particular case, flash an LED in a 1s interval.
It works perfectly on the breadboard but for some reason it failed when I attempted to make it on a single hole PCB board - the LED becomes lit but doesn't flash. Following images are from the said PCB board, and while I don't expect a direct answer (it doesn't work because of this and that) I would very much appreciate a hint - as vague as it is possible.
The last 220μF capacitor was added (but wasn't wired) to dim the LED gradually - hence the 2x 470Ω resistors instead one 1k.
Any suggestion and constructive criticism is also welcomed, thanks in advance!
Đorđe Jocić
Joined Aug 15, 2019
14
Thank you very much for your input! In addition to that, after reviewing the circuit again, I have noticed the transistors were wired incorrectly - E and C respectively. My first derp moment in electronics. :)
Audioguru
Joined Dec 20, 2007
11,248
Your schematic shows transistors that do not have the very important part number.
North American 2Nxxxx little transistors have pins that are in the order of EBC.
European BCxxx little transistors have the reverse order as CBE.
Oriental little 2SCxxxx transistors have the collector as the center pin.
dl324
Joined Mar 30, 2015
18,326
Welcome to AAC!
If you're serious about learning electronics, you should add component designators on every component and part numbers when appropriate. If you're going to use an NPN transistor to drive the LED, drive it low side instead of high side.
Aside from the connections on the base of the transistors, we prefer to use 90 degree wire bends with no unnecessary jogs. Ground always points down.
dl324
Joined Mar 30, 2015
18,326
If you do a PCB layout, even if you're going to wire point to point, it can give you a component placement that minimizes wire crossings and allow you to use uninsulated wire for most of the interconnect.
Here's a layout I did for 4 discrete R#S# flip flops. Each flip flop is about the complexity of your oscillator. It's on a board 2.5"x2.7" board:
Component layout showing jumpers:
