Orgone Generator Circuit
AndreaDP100
Joined Oct 26, 2024
12
Please can I have your opinion ?
I would like to make this circuit on a breadboard but I can't find the ac127 NPN transistor.
Can you please suggest an equivalent transistor I can use?
More generally the circuit does not have a power supply. It should multiply the input signal coming form a wi-fi antenna and drive the transistor.
I can provide more information if needed.
Can anyone figure out if this circuit has a sense on not?
Many many tanks,
Andrea.
P.S. The # is a common mode inductance
The #8 is a quartz crystal that (should) emit orgone energy.
Danko
Joined Nov 22, 2017
2,247
Check that link: https://www.retroamplis.com/AC127/EN
Also you can place antenna under orgone pyramid:
https://www.amazon.com/Accumulator-Element-Zen-Protection-Meditation/dp/B09F5KRJ8Q
ADDED:
An introduction to Measuring Orgone Energy
28,490
The circuit has to be a joke!! For starters the 1N4148 is a small signal diode not suitable for use as a voltage multiplier element. Next, you can not have power both entering and leaving thru the same point at the same time. In addition, germanium transistors in that case style can not handle either the voltage or the current, EVEN IF they had adequate frequency response.
This circuit is an example of the worst that the "Cartoon Channel" has to offer.
AND, this is the same TS that is seeking a transformer scheme to provide a voltage gain of 250 to apply power to a crystal. Something here does not smell right at all.
boostbuck
Joined Oct 5, 2017
1,066
The circuit is obviously a crock, and as pointed out above components are inappropriate for the intended function.
What tells you that a quartz crystal driven with AC will emit orgone energy?
28,490
I am not aware of whatever "orgone" is. I had guessed it was a typo for "ozone", but now I See that is not the case. It would do the whole world a large favor if all of the bunk websites were identified as fiction sites, not to be confused with reality.
AndreaDP100
Joined Oct 26, 2024
12
Dear MrBill2,
Thank you Mr.Bill for your reply!
I really wanted to hear your opinion with your competent sharp and straight language... -:)
You are right, the circuit does not work (from tests :even applying a real 1khz 5v sine wave there is no output)
Let me explain the rational part...
What I am trying to get is called reverse piezoelectric effect.
when you compress piezoelectric crystals they produce electricity.
The idea is: if you apply an electric field with 2 connectors to a quartz crystal it should start resonating.
This resonance, somobody believes, can produce and orgone field.
Not a scientific theory but worth to investigate.
Bigger is the electric field and the number of volts bigger should be the effect...
My limit is a reduced knowledge of electronics... probably I should have studied more, instead of wathcnig 'Cartoon Channel' too much!
28,490
Dear MrBill2,
OK, an interesting theory, based on an actual reality, but stretched "rather thin."
The piezoelectric effect is bi-directional, so that indeed a voltage applied to a piezoelectric material can produce some motion. BUT the possibility of "resonance" depends a whole lot on the material, and the manifestation of any such resonance may not even be observable except exclusively by mathematics. What that means is that some things can not be measured nor physically verified to exist.
In the case of a piezoelectric material, such as a crystal, actual resonance can be verified by observation of the voltage to current phase relationship.
In the reams of actual science, resonance is understood. I have several mechanical engineering texts that discuss it in minute detail, and all of the effects that it can produce. So any claims of additional "Field Generation" seem rather more the realm of entertainment fiction or some theological mystery far different from the realms of science and reality, not discussed among this website.
AndreaDP100
Joined Oct 26, 2024
12
It's a great question. Well it's a non scientific theory but is worth some tests...
AndreaDP100
Joined Oct 26, 2024
12
View attachment 334897View attachment 334898
ADDED:
Thank you Danko,
This is really interesting. I will check this...
I'd love to know how the sensor is made and what actually measures.
If you use a Theremin (produces sounds relative to the movements of the hands) you get a similar relsults.
it uses condensers property to detect how close is the hand...
28,490
Every bit of the functionality of a theremin device can be satisfactorily explained using well understood physical technology. All of the "Magic of the Theremin" is in the skill of the user.
AndreaDP100
Joined Oct 26, 2024
12
Yo are right Mr. Bill.
We talk about science and not of entertainment fiction.
But, please, follow me for a second: There were many things in history that were not science but know they are.
Science can't explain everthing. For example we can't esplain completel Gravity a force under human eyes since six milions years.
Gravity is a force that keeps your feet on the ground yet no such ‘force’ actually exists. At least science is no able, to fully explain it. E.g.Why it’s only attractive ? (if we knew how to reverse it we could build objects floating in the air) Is there a particle responsible of it? yes it’s the graviton but it’s only a theory, it was never observed.
Children at school are still taught that gravity is a force of attraction. However, in 1998, astronomers discovered, to their immense surprise, that the expansion of the Universe is speeding up… They have attributed this to the repulsive gravity of mysterious ‘dark energy’, invisible stuff filling all of space. According to Einstein’s theory of general relativity, gravity is the result of distortions in space-time created by mass and energy. We are far from a full explanation.
All this is to say that science knowledge still has some limits even on explaining energies and forces already known by ancient Greeks.
Early Greek which introduced the first form of democracy and were masters at their times in architecture and science, believed that lighting was a weapon of Zeus. Now we know that they natural phenomena resulting from the buildup and discharge of electrical charges in the atmosphere. We can measure them, predict them and build lightning rods.
Galileo Galilei invented the scientific method in 1600. Let’s imagine we approached him explaining that electric current flows in a metal due to the movement of free electrons. DaVinci probably would have categorized this as magic or bizzarre ideas or "some theological mystery far different from the realms of science and reality, not discussed among the Renaissance -:)."
Wilhelm Reich doctor of medicine formulated the theory of the orgone energy. I do not believe blindly in it.
Orgone is considered a pseudo-science form scientific mainstream. But a lot of energies and forces surrounding us still have to be explained.
We can’t explain scientifically concepts like Prana, Reiki, Orgone Energy as well as power of prayers. One day probably we will.
Simply I found a circuit that claims to produce orgone energy and wished to do some test...
This is an active cirqiut.
the ouput is a sort of 3 khz sqare wave about 3 v pp (power supply is 5v)
28,490
Gravity is only attractive for the simple reason that all of the materials that are repelled by it have been leaving for quite a while, hence the "rapidly expanding universe" that is now claimed. And all of those people making the claims about that, and the "dark energy", are in professions where none have the means to check the validity of the claims.
How INCREDIBLY CONVENIENT THAT IS!!!
It does make sense that the gravitational effect would have a conjugate of repulsion, with that being an intrinsic property of materials. AND, since, mostly, Force =Mass Times Acceleration, and if the gravity effect is constant and all of that Mass that is leaving is constant, then obviously it must be still accelerating. But folks never noticed it because it is far away, and most people have better things to do with their time.
28,490
Wonderful, It's a great idea...
Thank you!
GIVEN that all life forms OF INTEREST TO US NOW are composed of various molecules, which are built up of atoms, which have been demonstrated to contain electrons, I assume that device detects electrical fields.The widow of a very good friend purchased an electrical field detection and measuring device, for much more than she could afford, and demonstrated that it certainly can detect electrical fields. It showed that I had a fairly strong electrical field, which being alive was to be expected. We did not have any dead folks around to do a comparison.
