KeepItSimpleStupid
- Joined Mar 4, 2014
- 5,088
The 85 ohms resistor is then likely a "fuse" or a current limiting resistor. So, it's there for "protection".
True. Since the tester contains the circuit your building, Why not measure across the integral tester resistors to effectively confirm the numbers that you set?So the part of the circuit where the voltages are measured across is part of the tester. That's our conclusion so far.
