When a multi op-amp package(dual, quad opamp, multi channel etc) gives the current output in the datasheet does it specify the current output for EACH op amp seperately, or the total from all of them meaning you divide the output spec by all op amps?
Has anyone seen any circuit design utilizing "multi-channel" op amps to combine the max current output for higher power? If I have a quad opamp package with a supply current of 5mA, can I use them together for 20mA output?
