Opamp gain
Scooter1972
Joined Mar 14, 2020
I was just looking at the opamp worksheet. The negative feed back non-inverting opamp gain formula was given as Av=r1/r2 1. I believe it should be Av=r1/r2 +1
SamR
Joined Mar 19, 2019
5,534
The plus 1 depends on whether it is a positive or negative amp. Negative gets a - sign and Positive gets a 1+.
28,125
OK, sorry about that. Ri= the resistor in series with the input voltage to the inverting input. Rf = the feedback resistor connected between the opamp output and the inverting input.
The added "+1" is because with an input to the non-inverting side there is always at least a gain of one (unity gain).
seanstevens
Joined Sep 22, 2009
323
"I must admit that your answer has caused some confusion for me"
I actually thought that was a bit of humour in response to your statement "I dislike confusion"?
28,125
Some writers utilize conventions that are unknown to large segments of the population, for reasons that I do not see. Unconventional uses of words, in the manner of London schoolboy slang, can certainly convey incorrect meanings and cause problems.
For op-amp basics, though, input and feedback are rather the most basic concepts, and thus Ri and Rf should be clear, while R1 and R2 must reference some circuit drawing.
LvW
Joined Jun 13, 2013
2,035
You can believe me - I was able to imagine what you mean with "Ri" and "Rf"
However, from your sentence " I dislike confusion. And 1+Rf/Ri, as well" I have derived that you dislike the expression (1+Rf/Ri) "as well".
THIS has caused some confusion for me.
dl324
Joined Mar 30, 2015
18,453
For those of us who don't know what worksheet you're referring to, could you post a schematic and link?
Assuming you spelled things correctly, which I doubt because we use R as resistor designators, and r1 is the feedback resistor and r2 is the input resistor, the plus sign is indeed missing. That would be a critical error in something supposed intended to be educational.
LvW
Joined Jun 13, 2013
2,035
Yes - I totally agree with you.
However, even "conventional" uses of words/terms can and will convey incorrect meanings and, thus, cause problems for a correct understanding. Examples?
* "Current source" (in fact, a voltage source with a large static or dynamic internal source resistance)
* "Injecting a current" (in fact, we cannot "inject" a current - we realize a voltage divider with Rload<<Rsource)
* "Transistor current gain" (this is not really a "gain" because Ib is not the cause of Ic).
* "Current I creates a voltage across R" according to V=I*R (the formula is, of course, correct - but a current never can "create" a voltage. The other way round: A current needs a driving voltage)
28,125
OK, AND, FOR THE RECORD!! That was an error on my part!
It is the confusion created that I dislike.
Op-amp gain expressions are friends that help me. I like them.
Sentence sequence can lead to delivering wrong impressions, which I demonstrated quite well in that instance.
LvW
Joined Jun 13, 2013
2,035
Thanks for these honest words.
