OP Amp stability at gain <1
CWatters
Joined Apr 25, 2019
I'll soon be building a differential amp/buffer using an OP Amp (possibly a OPA1637 or TPH210). I'm a bit rusty but recall that stability can be an issue when feedback is configured for low gain. I'll be aiming for a voltage gain less than unity, more like 1/5th or 1/6th. I don't need the high bandwidth this would normally produce. Less than 60kHz would be OK.
Am I likely to have stability issues? Any pointers to for how to prevent them? Low pass filter in the feedback path?
CWatters
Joined Apr 25, 2019
Thanks.
I've also just had a look at the data sheet for the THP210 and it explicitly states its stable at unity gain and below.
AnalogKid
Joined Aug 1, 2013
12,266
Datasheet gain and phase plots look OK. What are you interfacing that needs sub-zero, balanced gain? There are a lot of precision opamps and inamps with less open loop bandwidth and gain, that might be less finicky.
ak
