Hi Folks,
I'm writing to ask for ciruit validation. I'm very begginger to electronic and my knowledge was based on some polish books and some of texas instruments manuals I could find in the internet. I'm trying to build a timegrapher and I "pre-designed" the circuit to gather sound signal from the watch. According to my assumptions cirucit should consist of:
-stabilized power supply +12 V
-op-amp to gain microphone signal
-high-pass filter
-inverting comparator which should give output signal to uC
I have some concerns about if I'm doing everything properly. I list them below in description of each part. I'd appreciate if You could help me in solving it:
-Stabilized power supply:
Designing this part was based on internet tutorials. As a V1 I used 18V/1A stabilized power supply. Then I made gretz bridge and split it to receive two receive two types of voltages:
+12V - to supply op amp which required 6-16V voltage
+5V - to supply uC
In both sources of supply I used stablizer series 78xx respectively to voltage I wanted to receive. Before and after stabilizer Iput capacitors 0,1uF to filter high peak voltage noise.
To pre-stabilize voltage in both cases I used 1000uF tantalum capacitor. I read that easiest way to find good capacitor to filter is to use a rule which states that for each 1A of supply current I should use 1000uF filtering capacitor.
1) Question: In this case current splits equally 500mA each wire. Shall I use 500uF instead?
When I made simulation everything looks correct: Voltage measured close to R1are around 5V DC and same right after 12 V stabilizer. Below screenshot:
Next is op-amp. Here I used ready to work kit from some polish online shop. It is dedicated to electret microphones and according to specification has 100x gain. Power supply should be from range between 6-16V. Below I upload the circuit
I made a simulation of whole cirucit. Below I'm uploading whole ciruit from LT Spice so You can quickly checked against above picture if anything is wrong.
Resostpr R8 represents rest of ciruit.
V2 = 0,01V/1kHz represents signal from microphone.
I made simulation to see gain of an op amp and if everything is right. Below are the plot of
-non inverting input signal (+) - (Red line)
-output signal of op-amp measured right before C11 - (Green line)
-output signal measured between R6 & R8 - (blue line)
Plots look respectively:
2) Why signal till around 0,35 looks so strange?
3) What causes and why such big drop of voltage between green and blue signal? There is no gain between input (0,01V of microphone singal) and blue one?
Filter design:
I made high pass filter based on the texas instruments manual "design of filter in 30 seconds:
http://www.ti.com/lit/an/sloa093/sloa093.pdf
I'd like to connect it to the circuit (in R8 place):
cut off frequency = 10 kHz
C1=C2=3,3nF
R1=R2=3,4kOhm
Cout=3,3uF
4) Will that designed filter work with op amp?
5) Can I use simple TL072 Op amp or shall I use different solution?
Comparator:
Do You have any data how should I could calculate resisor/capacitor values for comparator?
Thanks for Your help and validation.
Regards
Kuba
-high-pass filter
+5V - to supply uC
Filter design:
C1=C2=3,3nF
R1=R2=3,4kOhm
Cout=3,3uF
Comparator:
Regards
Kuba
