Op amp oscillator
Zeeus
Joined Apr 17, 2019
616
Trying to understand circuit myself but....
Circuit is correct?
Think that second op amp has the inputs interchanged
Anyways, someone please make oscillation on spice
Thanks thanks.
DarthVolta
Joined Jan 27, 2015
521
I am also learning op-amps circuits, I can just about walk through what this ones doing. I should be-able to calculate the basic info. But I'm supposed to be working on other stuff.
There's a ton of circuits I want to make now, but I'm obsessed with fixing my DMM 1st
MrAl
Joined Jun 17, 2014
13,702
Sorry, but your .asc file gives me a syntax error and aborts.
Does it run on your computer?
Open the .asc file in a text editor, then remove the last line.
Then open the schematic in LT Spice, then make a transient analysis command,
then reverse the power supply connections to U1, then run the analysis, then choose the output to view the waveform. It doesnt work as an oscillator yet though looks like it needs more work yet.
Oh R7 has to moved too.
Or start with this...
MrAl
Joined Jun 17, 2014
13,702
Circuit is correct?
Thanks thanks.
To start, you have U1 power supply connections reversed.
Looks like it might need more work though.
Here's a new asc file to try and work with:
Zeeus
Joined Apr 17, 2019
616
lol
Reversing U1 made it work
Sorry for wasting your time "guys"
LvW
Joined Jun 13, 2013
2,024
Just a short remark (as it was not mentioned up to now):
Your circuit is one of the alternatives to use two integrators in a closed-loop for realizing a harmonic oscillator. Here we have the classical inverting MILLER intergrator in series with the non-inverting NIC-integrator (DEBOO integrator).
MrAl
Joined Jun 17, 2014
13,702
I had to remove the very last line again and put R7 back in the right place or i would get a "floating node" error. The .asc and result files are attached below.
In the .asc file, it was only the very last line that was causing LT Spice not to open but this time the simulation command did not have to be removed. Maybe i have an older version of LT Spice. Apparently it does not like the last line being blank (crlf but no other information).
Now it runs but the frequency looks closer to 4kHz.
schmitt trigger
Joined Jul 12, 2010
2,076
This circuit appears in Thomas Frederiksen's book Intuitive IC Op Amps.
The ASC circuit has the inverting and noninverting terminals swapped on both opamps.
So it is still oscillating, but the oscillation mechanism is different from the original author.
MrAl
Joined Jun 17, 2014
13,702
I did think the design looked kind of over complicated, but i did not look for advantages of doing it this way either.
Zeeus
Joined Apr 17, 2019
616
I think there's an error in the book schematic
Disagree?
