Op amp not working as expected
roci75
Joined Feb 26, 2024
6
Hello guys, I bought an op amp from mouser, the LMP7721 (data sheet below).
I have been testing it, I soldered it to a break out board.
after connecting 3.3v supply from an arduino uno to v+ and v- and connecting in- to vout I measured between ground and in+ 1.2 to 1.8 V.
if I disconnect vout from in- , vout shows 0v
And both in- and in+ show 1.2 to 1.8 V.
can I assume that the op amp is broken?
ps ( I actually bought 2 LMP7721 but I’m waiting on desoldering alloy to be able to switch the other one with the one is in the break out board).
Any way, I hope some one can help me, I am grateful for any assistance.
link to data sheet:
https://www.ti.com/lit/ds/symlink/lmp7721.pdf
Papabravo
Joined Feb 24, 2006
22,113
link to data sheet:
The language of electronics is the schematic – not English.
roci75
Joined Feb 26, 2024
6
No. You cannot measure input voltages directly because the inputs have very high input impedances.
Show us a diagram of your test circuit.
Here are two simple test circuits:
Hi MrChips, just wanted to thank you for your help, I tested the op amp with the non inverted circuit you showed ant it is working now.
I assumed that when there is no input to the op amp it would out put 0v but apparently it doesn’t work predictively when there is no input.
35,223
It is a newcomer mistake to think that when there is no input it is at 0V.
This is not the case for high impedance inputs on analog and digital circuits.
A high input impedance means that the input is an antenna that can pick up every radio, TV, cell phone, bluetooth and 50Hz/60Hz AC line voltage signal.
BobTPH
Joined Jun 5, 2013
11,662
Why are you measuring the voltage at a floating input? That is meaningless. Connect the input to a known voltage and measure the output.
