Help me, this circuit is not working properly as expected
Erebus21
Joined Nov 27, 2024
this circuit is not working properly as expected ,signal from the arduino is given to the pstart,relay stays on all the time,can any help me diagniose?????
BobTPH
Joined Jun 5, 2013
11,664
It may not work as you expect it to, but, if the relay is on always, it works as I would expect it to.
The Arduino can output either zero or five volts. In both cases current flows from the +12V through the LED in the opto coupler to the lower voltage.
AlbertHall
Joined Jun 4, 2014
12,654
As explained above the circuit cannot work.
You could connect P_start to gnd and disconnect R6 from the 12V supply and connect it instead to the arduino output pin.
This will reverse the operation so the relay will be on when the arduino output is high.
BobTPH
Joined Jun 5, 2013
11,664
And, unlike the original circuit which defeats the purpose of the opto coupler, that gives you isolation.
