In ltspice I have 3.465v steady at the + input of an op amp. The negative input oscillates between 3.47168 and 3.47654. The output is oscillating between the + and - saturation voltages. I connected a .22 ohm between the + and -. This stopped the output from oscillating and I had a steady output voltage of 3v. The power supply is 8v. The op amp is lm324.
When I built the actual circuit I had approx. 0v at the output. I then tried a 1 ohm resistance with the same result although the ltspice simulation was ok.
It looks like I have a common mode input in the actual circuit. I can try larger resistance values but is this going to help?
