It's unclear what you are doing there. The outputs seem to go down and stop. That's doesn't make sense.
It looked different than LT Spice that's why I mentioned it, but it looks like you are working on Apple so the appearance will be a little different.I'm using LTspice, but I've found that to be a limitation of the opamp
Try going through it stage by stage and see if you can spot which stage is causing the problem. That's a basic troubleshooting technique.I have another question, I'm making the circuit but I get the output signal
| Thread starter | Similar threads | Forum | Replies | Date |
| W | Review Request: 220V TRIAC Voltage Stabilizer using LM358 and UJT | Homework Help | 8 |
