Hi
Please have a look on the attachment. Are the connections correct? When I was trying to build this circuit some days ago, someone was saying that I need two separate power supplies to power up the op-amp and personally I was confused too about it. The power supply had only two terminals +ve and -ve and a knob to change the voltage level. I had set the knob at 15V. One thing really confuses me that there is no reference (ground) for the voltages of power supply; e.g. +15/-15 volts with respect to what? Could you please help me? Also I didn't have access to o-scope to check the Vout waveform. Thank you.
Regards
PG
Regards
PG
