Only one resistor on one side of a parallel circuit.
Aldeatho
Joined Dec 2, 2020
Hey guys,
Struggling a bit here as I can't seem to find anything online (including in this forum) regarding placing one resistor on one half of a parallel circuit.
The source voltage is 12 volts DC, the first voltmeter (V1) is connected in series with the source, measuring 12 volts. After the first voltmeter (V1) the source lead is split into two paths, forming a parallel circuit. Along first of the parallel leads is the second voltmeter (V2); it is the only component along this parallel lead. Along the second of the parallel leads is a 10 ohm resistor (R1) before and in series with the third voltmeter (V3). The parallel leads then rejoin before the fourth voltmeter (V4) and return to the source's negative.
What would the voltage measurements at voltmeter 2 (V2), voltmeter 3 (V3) and voltmeter 4 (V4) be and why? I appreciate any feedback as I don't have any components I can test this with. Also, if this question is already answered please direct me to that resource.
Aldeatho
Joined Dec 2, 2020
Lol I made it in Gimp XD... I found the answer I was looking for though: there needs to be resistance on both parallel lines to avoid a short circuit. Also, the current divides into two when a lead is split into two, not the voltage. It's clear I was short-circuiting... Thanks for your replies though :).
BobTPH
Joined Jun 5, 2013
11,647
If this is really a homework problem, I would love to see the actual assignment. Both of your diagrams are nonsense. The first shows loops with the voltages not adding up to zero (Kirchoff’s voltage law.). The second shows all the voltmeters shorted out as well as the entire circuit being a short.
Hopefully, neither of these was given to you by the teacher.
