Capacitor charging time in a circuit which has resistor in its output side.
san514
Joined Jul 9, 2018
5
Here the input voltage is 0.040V and current is 0.013A what will be the charging time of the capacitor?
[There is a diode at the input side.The red circle is LED and it has a switch at the end.]
WBahn
Joined Mar 31, 2012
33,327
Is the input voltage 40 mV rms? or peak? or peak-to-peak?
Where is this 13 mA coming from? If the source is a 40 mV, then it is establishing the voltage across it. The current will be whatever the current is.
MrAl
Joined Jun 17, 2014
13,885
Are you really saying the input voltage is 0.040 volts? It doesnt matter if that is RMS or Peak it is not high enough to make the diode work as a diode, and even if the diode did work as a diode the LED would not work because the LED forward voltage is far too high for that (1.5 to 3.5 volts approximately).
Thus there is no current flow.
Did you mean maybe 4v or even 40v or something?
I think you should double check that first.
san514
Joined Jul 9, 2018
5
It's 4v
san514
Joined Jul 9, 2018
5
Its 4v exactly.sorry posted it wrong by mistake.
san514
Joined Jul 9, 2018
5
4v
ericgibbs
Joined Jan 29, 2010
21,641
hi san,
Your duplicated Thread in the Projects Forum, on the same Topic, has been deleted.
Please do not Create duplicates.
MOD.
