Question about NPN low side switching schematic, finding base resistor.
gandoN9
Joined Oct 12, 2020
18
First thing i need to do is to find R1 knowing Vcc is 9V and LED current is 20mA.
So i am calculating R1= 9V-3.3V/20mA = 285 ohms, i will choose 330 ohm resistor.
Transistor beta gain is 100
Second task is to find R2 size, which would be in saturation for 3.3V input signal.
So i need to calculate Ic (collector current) Ic= Vcc-Vce/R = 9V-3.3V/330 = 17mA (0.017A)
Then i need base current. Ib = Ic/B(beta) = 0.017A/100 = 0.00017A
And then finally Rb =Vin-Vbe/Ib = 3.3-0.7V/0.00017A =~15k ohms.
Are my calculations for finding Rb right?
Help will be appriciated, thanks!
AlbertHall
Joined Jun 4, 2014
12,653
Only if this is a simulated circuit where the gain of the transistor can be precisely specified.
With a real transistor the gain values can have a very wide spread, and further will vary with collector current and collector voltage.
A rule of thumb to make sure the transistor is saturated is to make the base current 10 times the value you calculate like that.
N.B. Your circuit shows two LEDs in series. Is 3.3V twice the expected individual LED voltage?
Papabravo
Joined Feb 24, 2006
22,111
NO. The beta of a transistor is for the current gain in an amplifier, and it varies a great deal among transistors of the same type. In practice for a specified beta of 100 it could be anywhere in the range of 50 to 300 for a typical transistor. For a switching application what you wan to do is force the beta to be about 10. So in your example with Ic = 17 ma, you choose Ib = 1.7 ma. The collector current can never be more than 17 ma, limited as it is by the collector resistor and the forward voltage of the LEDs.
Compute R2 to allow the signal generator to supply 1.7 ma @3.3 Volts, and you are done.
Now the actual beta of the transistor is irrelevant.
gandoN9
Joined Oct 12, 2020
18
Thanks for fast reply.
I am using BC817 transistor, looking the data sheet:
Says the minimum hfe is from 100-600. So i am using beta 100
Do i still need to change something?
35,189
Yes. For putting a transistor into full saturation you can ignore the datasheet current gain.
As a rule of thumb, use a current gain = 10.
For collector current = 20mA, use base current = 2mA
Base resistor = 2V / 2mA = 1kΩ
Papabravo
Joined Feb 24, 2006
22,111
Yes. A "switching" application for the transistor is fundamentally different from an "amplifier" application. In your "switching" application the transistor is always in one of two states: saturation (fully on) or cutoff (fully off) with a very short duration transition between the two states. In an "amplifier" application the transistor spends all of its time in the linear region and never goes into cutoff or saturation. If an amplifier dis this you would observe clipping and distortion on the output. Generally you don't want an amplifier to do this. In your switching application you make sure the transistor is in saturation by overdriving the transistor and using external components to force the "beta" of the circuit to some small value like 10. It could be 8 or 12 or some other number in that order of magnitude. It just needs to be a small fraction of the beta you would use to design an amplifier that operates in the linear region. In a "switching" application, you are trying to ensure that the transistor spends NO APPRECIABLE AMOUNT of time in the linear region.
dl324
Joined Mar 30, 2015
18,470
Yes. You're using the transistor in saturation mode and should be using this data:
Note the collector and base current information. Some BC transistors specify a beta of 20 for saturation mode; this one is 10. So you should always consult the correct portion of the datasheet.
gandoN9
Joined Oct 12, 2020
18
So i did new calculations then :
Finding R2:
1) Ic= Vcc-Vce/R = 9V-3.3V/330 = 17mA (0.017A)
2) Ib = Ic/B(beta) = 0.017A/10 = 0.0017A = 1.7mA
3) Rb =Vin-Vbe/Ib = 3.3-0.7V/0.0017A = ~1,5k ohm resistor
Is this looking okay now?
djsfantasi
Joined Apr 11, 2010
9,237
Finding R2:
Are you sure Vce is equal to 3.3V?
dl324
Joined Mar 30, 2015
18,470
Check the first equation.
Equations are easier to read if you use LaTex:
\( R_b = \frac{V_{in}-V_{be}}{I_b}=\frac{3.3V-0.7V}{1.7mA}=1.53k\Omega\)
EDIT: corrected equation and typo.
gandoN9
Joined Oct 12, 2020
18
Thanks for many answers guys!
So after watching some simlations about this circuit and making new calcs:
Finding R2:
1) Ic= Vcc-Vce/R = 9V-0.2V/330 = 0.026A
2) Ib = Ic/B(beta) = 0.026A/10 = 0.0026A
3) Rb =Vin-Vbe/Ib = 3.3-0.7V/0.0026A = 1000 ohms
Thank you guys!
Papabravo
Joined Feb 24, 2006
22,111
I knew that. I wanted to find out if the person doing the homework did?
I think he might be in overload mode, by substituting one thing for another without realizing that there are multiple things going on.
  1. Collector supply voltage, 9 V nominal
  2. Collector resistor 285 to 330 Ω
  3. Forward voltage drop of 2 LEDs, approximately 3.3 Volts
  4. Voltage drop across the Collector Emitter Junction, 0.2 to 0.4 (guessing, without consulting data sheet)
BobaMosfet
Joined Jul 1, 2009
2,211
This book will be invaluable to you:
Title: Understanding Basic Electronics, 1st Ed.
Publisher: The American Radio Relay League
ISBN: 0-87259-398-3
