Driving High Side NMOS Question
OozmaKappa
Joined Dec 15, 2019
So I'm working on an H-bridge but don't have any PMOS to use on the high side. I'll probably end up just ordering some and/or some new drivers, BUT I was wondering if I could emulate a high side driver using the circuit below. When the pulse goes high, Vcap becomes Vpwm + Vcc, and it drops to Vcc when the signal goes low. The pulses would be swapped on the other half.
Currently, I am using a pair of TC4424A and IRFZ24N FETs.
If there is a more appropriate way to use a charge pump in this instance, please let me know. Thank you!
Alec_t
Joined Sep 17, 2013
15,158
Even if the post #1 circuit worked in principle, most of the energy for charging the high-side FET gate capacitance would have to come from the non-inverted pulse source; which doesn't seem practical.
