Driving a high side switch/mosfet/etc. from a 3.3V PWM output at 20kHz?
wittrockvita
Joined Nov 13, 2020
I need to drive a high side switch (mosfet or equal) from a 3.3 output at 20kHz. The load requires 15V - 3 Amp.
Haven't been able to find any suitable solition, så if any of you can push me in a good direction It will be highly appreciated!
wittrockvita
Joined Nov 13, 2020
How about a P FET with the gate pulled up to source with a resistor. Then either a N FET or NPN to pull the gate low when needed.
That is not posible at 20 kHz PWM because of the large gate capacitance of a mosfet - the resistor can't simple chrge it fast enought even if it very small.
dl324
Joined Mar 30, 2015
18,491
It's likely worse than that. A pull up resistor to 15V would be forcing current into the output of your uC. If you exceed the maximum voltage allowed or current forced in to the output, you'll trigger the parasitic SCRs that exist in all CMOS devices.
To do it "right", you need a level shifter, inverter (or two), or a gate driver.
ronsimpson
Joined Oct 7, 2019
4,853
V1 is the signal from the computer 0/3.3V.
V2 is the 15V supply.
M1 is a P-MOSFET (not logic level)
R3 amplified by Q2 turns off the MOSFET. I used Q2 to speed up turn off time.
Q1 turns of the MOSFET.
When V1=3.3V, q1=on, M1=on.
geekoftheweek
Joined Oct 6, 2013
1,429
Your response to my poor suggestion may have answered a failure in a current project of mine. I've never had to consider speed before in my own projects. Good luck.
