Old transistor, C5215, looking for a replacement
marcelo_longobardi
Joined May 15, 2024
Hello everyone, I'm looking for a replacement for an old power transistor, C5215, it's used on a Sega Saturn videoconsole, I couldn't find its datasheet on the entire web :(, just found some sellers on aliexpress but not much else. Could anyone bring me some light?
At its side there is another power transistor, D1858
This PSU is a japanese one, input is 100VAC
dl324
Joined Mar 30, 2015
18,478
marcelo_longobardi
Joined May 15, 2024
michael8
Joined Jan 11, 2015
472
Is the transistor failed? If not completely it could be measured once removed from the circuit board which might supply some clues.
The best way is to trace out what each pin of the transistor connects to. This should allow figuring out which each pin of the
transistor is. It's a single sided circuit board -- those are easest.
