- Joined Jan 23, 2018
- 28,272
The terminals of the lower 2 output jacks are not "merely touching" the terminals of the upper two, they are, in fact, very deliberately connected and soldered.
So those are not the problem.
I suggest examining the "X" jumpers on the polarity switch, if they touch it will pop the fuse instantly.
AND, I suggest checking those two great big blue electrolytic capacitors for excess leakage. That sort of cap seldom lasts forever.
In that regard, you could power the panel thru a lower wattage rated light bulb and just leave it on for a few hours, to see if the capacitors will reform themselves. That might be the fix, cheap if it works and not a huge waste if it does not work.
