OBDII mobile tracker, reprogram to have one of the pins throw a positive or ground?
Hansen
Joined May 3, 2015
33
OBDII mobile tracker: Reprogram to have one of the pins throw a positive or ground? I am not using in a auto, just want to use it as a remote switch to operate a 12vDC 125ma device.
DickCappels
Joined Aug 21, 2008
10,661
Do you have any documentation describing the circuit and firmware?
Most likely you would have to make something that looks like a diagnostic port to plug it into and then the OBDII would communicate with the port.
Hansen
Joined May 3, 2015
33
Here are links to: a user manual, port plug, and standard PID for all OBDII's.
Note: I am not partial to this model, I will buy any model tracker if you recommend a different brand.
I am working on getting the firmware.
User manual
Female plug
Standard PID (see Hex 65 in chart: Says Auxillary input/output, so I hope it can throw positive or negative to control a 12vDC 125ma device.)
Standard OBDII pin layout attached.
Thanks!
