OBDII Breakout Box With LED Indicator
s200bym
Joined Aug 9, 2017
82
Hi All,
I'm going to build an OBDII breakout box but I want to add 3v 20mA LED's to show what pins are active. Would I need to do a circuit like the one in the picture?
Cheers,
Mike.
dl324
Joined Mar 30, 2015
18,446
Just because many LEDs are spec'ed for 20mA continuous, that doesn't mean you need to operate them at that current when they're used as indicators. A few mA may be sufficient.
What is the current sourcing capability of DATA without signal level being degraded to the point of being useless? How much capacitance can they drive?
Why not opt for something that doesn't load signals? Using comparators or CMOS buffers to drive the LEDs will have less impact on the circuit.
s200bym
Joined Aug 9, 2017
82
@dl324 Thank you for your reply.
I had a search on google and found a schematic using the LM358D which I have copied on Eagle. Is this what you were referring to?
Cheers,
Mike.
s200bym
Joined Aug 9, 2017
82
I was looking at that and may consider it, but I want the fun of making it :) I was thinking of adding grounds for all the pins.
dl324
Joined Mar 30, 2015
18,446
An opamp can be used as a comparator, but it's not usually recommended.
This is what I had in mind:
Opamp supply connections and decoupling omitted for clarity.
R3 and R4 determine the maximum voltage for a LOW signal level. Whenever the inverting inputs to the comparators are above that voltage, the corresponding LED will be turned on.
Most comparators don't sink a lot of current. IIRC, LM393 are guaranteed to sink around 6mA, but typical is 15mA.
I drew the schematic in Eagle. I printed to BW PDF, because many are of the feeling that color coded schematics aren't useful.
I'm not a fan of using IC pin order symbols in schematics because they make for unreadable circuits.
Hymie
Joined Mar 30, 2018
1,347
My knowledge of OBDII signals is close to zero, but given the bus is carrying digital signals (at reasonable switching speeds) the usefulness of the LEDs must be very limited – cheaper versions of breakout boxes are available without the LEDs.
wayneh
Joined Sep 9, 2010
18,133
My OBD II tool was only about $10 and enables my phone to access it over WiFi. I wouldn’t dream of trying to build one. Put the energy into something new.
s200bym
Joined Aug 9, 2017
82
It’s not a dongle type elm tool. It’s a breakout box so you can easily measure each pin with an oscilloscope, DMM, etc.
@dl324 I will have a play around with your circuit thanks.
Mike.
ToreanPW
Joined Apr 28, 2024
S200BYM did you ever get your breakout box running. I am starting the same venture as there are options on the market but none have all the features and abilities I want.
I have seen suggestions of micro controllers, and as simple as a 200ohm or 1k ohm resistor inline directly off of the can line.
Any information you may have found or tried would be great
