Maybe overboard with the breakout boards.
robp1956
Joined Jun 12, 2026
121
I may have gone a bit crazy with the breakout boards. But in my defense I wanted to be sure that I had the right one with so many package types it's hard to decide. OOPS maybe next decade I will know. It will be that long before I use these up.
dl324
Joined Mar 30, 2015
18,521
Whatever floats your boat.
I'm more inclined to purchase extra of whatever I actually need so I'll have them on hand. I purchased 100 SOT-23 to SIP adapters, used up a couple dozen and ordered another 100. I ordered some SOIC16 adapters and cut one to use for 2 SOIC8 chips. Then I decided to buy the SOIC8 adapters that were narrower.
I also bought some SOIC to DIP adapters for testing parts in SOIC (e.g. 93C46R). I also needed to make an extra adapter because the mentioned device has a rotated pinout:
robp1956
Joined Jun 12, 2026
121
Well It seems that even though I thought I covered all the bases I did not. I received SOT 223, SOT89 breakout boards and it seems there are others that I missed it seems I need SOT23 that is even smaller than the SOT89. I managed to get a SOT23 chip to go onto a SOT89 breakout board but I don't actually trust it. So I guess for the final connection I will need the SOT23 breakout boards also. so I have SOT89, SOT223, Is SOT23 the last one I will need or is their others I should be thinking about.
Futurist
Joined Apr 8, 2025
952
Never buy one or two of such things, if you need one now you'll probably need one again at some point. I always buy a bunch of things like that.
dl324
Joined Mar 30, 2015
18,521
I use SOT23 more than SOT223 or SOT89 (I've never used the latter). I think SOT23 adapters are also compatible with SC89, which are even smaller than SOT23.
Regarding any others, I'd wait until I needed them and buy 50-100 of them.
schmitt trigger
Joined Jul 12, 2010
2,288
We all in this forum suffer from this same psychological disorder :(
When we see something that catches our attention, we really, really, really have to have it.
I just purchased a couple of vintage germanium transistors. Why? Because they are cool! Do I need a rational reason?
robp1956
Joined Jun 12, 2026
121
The psychological disorder was thrust upon me by Dennis In order to build the circuit he gave me. I think he secretly wants to drive me nuts. :)
robp1956
Joined Jun 12, 2026
121
Isn't buying germanium transistors a bit like buying a Simpson meter, fun to have but otherwise not much use. :cool:
dl324
Joined Mar 30, 2015
18,521
I have a Simpson 467:
It stopped working and I haven't spent much time troubleshooting it. Checked the battery and fuses and set it aside.
