numbers on elements
paultwang
Joined Mar 8, 2006
80
Originally posted by ravi_0605@Mar 12 2006, 04:59 AM
what does the numbers on the diodes and some other elements mean?
[post=14901]Quoted post[/post]​
The numbers are probably part numbers. They are also inscribed/printed on the components if possible.
Dave
Joined Nov 17, 2003
6,969
As well as being part numbers, some of the numbers and writing on components can be ratings; for example some capacitors have the capacitance value on the casing written <some number>uF.
Dave
alim
Joined Dec 27, 2005
113
Hi what do you mean by elements? components?--transistors etc?
22,116
[post=14970]Quoted post[/post]​
Element is a short expression for "circuit element". A circuit element is any individual piece of a circuit. It could be a passive component such as a wire, a resistor, a capacitor, or an inductor. It could also be an active component such as a diode, a transistor, a vacuum tube, or a klystron.
This list is neither complete, nor exhaustive, but you get the idea -- I hope.
Dave
Joined Nov 17, 2003
6,969
In this example, I think you'll find the word element is interchangeable with the word component. The best thing to do is look at the word in context.
Papabravo is correct in what he says about 'circuit element'; however I must say I don't here the word element often in my work.
Dave
alim
Joined Dec 27, 2005
113
[post=14973]Quoted post[/post]​
Hi I was trying to get what RAVI intended to ask. some of these terms may not carry the same meaning to another person.
22,116
[post=15035]Quoted post[/post]​
Ravi looked at a diode and asked what the visible numbers printed on the body of the diode were for. Then he asked about other "elements" which also presumeably had some letters or numbers or symbols printed on them.
The original asnwer was that the letters and numbers printed on circuit components are part numbers and possibly values that can be used to identify them and connect them with a datasheet.
One subthread was the use of the word "element" in place of the word "component". I think we have agreed that the terms are interchangeable and that the word "element" is not commonly used in this context.
I am fully aware that familiarity with English may be causing us some problems, and if I have misunderstood what you are asking then I apologize. It is certain that your English is better than my (pick your favorite language). So we do the best we can.
alim
Joined Dec 27, 2005
113
[post=15037]Quoted post[/post]​
Hi My response was only for clarification.Thanks.
