NTC Selection Criteria for 'Temperature range: -5°C until +35°C Accuracy: ± 1%'
ericgibbs
Joined Jan 29, 2010
21,567
Is trim pot essential in opamp circuit to set opamp gain ? because it would be difficult set the value of Trim pot value in mass manufacturing
If you buy components, there is no way you could guarantee that a particular component will have exactly the same parameters, so you will need so method of trimming out errors.
I did not realise that this project was for a mass production market.??
Which part of my simulation could not duplicate.??
E
BTW: the sim in post #81 is not my circuit.
mishra87
Joined Jan 17, 2016
1,063
E
You posted in post #74
The schematic was mine but your simulation results is different from mine.
In your simulation resistance in Xaxis increases from 6586 to 43834 ohm and at 43834vohn vout reaches Zero.
Could you guide me how to plot this resistance ?
Yes this project is for mass market and volume is high.
Regards
ericgibbs
Joined Jan 29, 2010
21,567
hi,
For some reason, the identical circuit plots from High resistance to Low on your PC and mine plots from Low to High resistance.
Also the Zero is different.
My LTSpice is up to date with the latest version.
I will keep looking
Edit:
post #69 @crutschow plots the same as mine Low to High resistance.
mishra87
Joined Jan 17, 2016
1,063
hi,
I will keep looking
pl look if you can find ?
Regards,
ericgibbs
Joined Jan 29, 2010
21,567
hi
Check this, place your cursor on the Xaxis label, Right Click, see a pop up , note the settings , are they same as mine.
Post an image of the pop up.
E
mishra87
Joined Jan 17, 2016
1,063
Hi All,
I am opening this thread again with some issue.
Hope i will get some recommendation from this forum.
Below is the resistance value form NTC vs temperature.
-542.327
-4.541.2435
-440.16
-3.539.1365
-338.113
-2.537.1495
-236.186
-1.535.2765
-134.367
-0.533.5085
032.65
0.531.84
131.03
1.530.264
229.498
2.528.7745
328.051
3.527.367
426.683
4.526.037
525.391
5.524.7805
624.17
6.523.5925
723.015
7.522.4665
821.918
8.521.401
920.884
9.520.393
1019.902
10.519.436
1118.97
11.518.5305
1218.091
12.517.6735
1317.256
13.516.8585
1416.461
14.516.0855
1515.71
15.515.355
1615
16.514.6625
1714.325
17.514.003
1813.681
18.513.377
1913.073
19.512.782
2012.491
20.512.2155
2111.94
21.511.6805
2211.421
22.511.1725
2310.924
23.510.686
2410.448
24.510.224
2510
25.59.787
269.574
26.59.3695
279.165
27.58.972
288.779
28.58.5925
298.406
29.58.2305
308.055
30.57.9135
317.772
31.57.587
327.402
32.57.249
337.096
33.56.9515
346.807
34.56.6695
356.532
Used Circuit :
NTC Details :
https://www.st.com/resource/en/datasheet/stm32f405rg.pdf
Source Variation for Vadc = 3.3V with 2% Accuracy.
Now my question is -
1. How much accuracy i can get using this circuit. ?
2. Can i able to get accuracy of 0.5degC or less. ?
3. How to theoretically calculate the accuracy of the NTC. ?
4. Can i get 0.1degC step measurement using this NTC ?
Thanks i advance.!!!
Alec_t
Joined Sep 17, 2013
15,156
If the voltage supply to R38 is the same as Vadc but isn't stable then I don't think you can expect better than 2% error, regardless of any NTC error. However, if the voltage is stable but has a 2% tolerance then you should be able to calibrate the system at accurately known temperatures, so that the error can be allowed for.
mishra87
Joined Jan 17, 2016
1,063
Thanks Alec_t
It was quit good information and although I am not expert but i had same thought about calibration.
Now I want to make it very clear that 3.3V is coming from LDO which has accuracy of 2%. I believe LDO output is stable but it has 2% variation thoughout the temperature. So LDO output may vary 2%.
The datasheet of NTC says that it has 0.2degC variation itself throughout the temperature range.
So as per my understanding the error at 35degC equal to ....
35×0.02= 0.7degC
Add 0.2 degC variation of NTC so total error is 0.9degC at 35degC temp and that is close to 1degC theroritical considering ADC itself error..
Now if you suggest for calibration how can it be done.
Could you suggest the calibration process as i am not much familiar about it ?
I think 1degC error is not acceptable.
Please enlight me more .
Thanks a lot
Alec_t
Joined Sep 17, 2013
15,156
Calibration would involve recording the circuit output when the LDO regulator is kept at one or more accurately known temperatures and the NTC thermistor is at each of a set of accurately known test temperatures. Therein lies a problem: you would need an alternative, very accurate method of maintaining and measuring those test temperatures.
To reduce error you could perhaps make use of a more accurate reference voltage source to supply the thermistor.
mishra87
Joined Jan 17, 2016
1,063
Hi Alec_t
Thanks for information,
As per current circuit both mcu adc supply (reference ) and NTC are connetected with same source and if there will be variation in LDo output there will be a change in both voltage.
Are you talking about fixing more stable source for NTC at R38 or microcontroller adc pin supply voltage.?
Still I did not get more perception NTC calibration ?
mishra87
Joined Jan 17, 2016
1,063
One more addition to above points that my micro-controller does not Vref Pin so it is considering Analog supply for its measurement.
Regards,
Alec_t
Joined Sep 17, 2013
15,156
If your micro is an STM32F, according to section 3.10 of its datasheet it has an internal reference voltage source and an internal linear temperature sensor, complete with calibration values. Can't you use those features?
mishra87
Joined Jan 17, 2016
1,063
Hi All,
I am still struggling with same issue trying with several permutation and combination but at the end no solution found that can be easily implemented.
https://www.digikey.com/product-detail/en/stmicroelectronics/STM32F405ZGT6/497-11909-ND/2757671
Calibrating temperature sensor or internal reference is tedious task in production.
Regards,
ebeowulf17
Joined Aug 12, 2014
3,307
Hi All,
Regards,
If you really want tight tolerances, high precision, and no calibration, you may need to fundamentally change your approach.
I'm not an expert at this, but I seem to remember that taking a high quality RTD and reading it through a wheatstone bridge is one of the more reliable ways of achieving better accuracy and precision without the need for manual calibration on a per-unit basis.
Most ways of measuring temperature will inevitable require individual calibration to achieve the accuracy you seek.
