NTC Selection Criteria for 'Temperature range: -5°C until +35°C Accuracy: ± 1%'
mishra87
Joined Jan 17, 2016
1,063
Generally you want a thermistor that has about 1kΩ to 10kΩ resistance at the center of your temperature range.
Pick one that is rated for 1% accuracy of value over the range.
If you connect the thermistor in the feedback circuit of an op amp in a quasi-bridge connection, then the output is a linear function of the thermistor resistance.
The LTspice of such a circuit is shown below for a typical thermistor:
The values shown give an output of zero volts at 20°C.
For your circuit you would likely want zero output at -5°C.
The gain is a function of the bridge reference voltage, Vb, which should be a stable voltage from a reference circuit, such as a TL431.
If you need more gain to match the micros input scale, than add a non-inverting op amp with gain at the bridge output.
Thanks a lot for your support.
That's what I wanted to know.
Is there any specific type NTC needed for water application.
What is your opinion about schematic posted in post #19
Thanks again !!!
mishra87
Joined Jan 17, 2016
1,063
If you connect the thermistor in the feedback circuit of an op amp in a quasi-bridge connection which maintains a constant current through the thermistor, then the output voltage is a linear function of the thermistor resistance.
Could you share LT spice file I don't find in LT spice library .
How to look resistance vs voltage graph in lt spice
thanks
mishra87
Joined Jan 17, 2016
1,063
Could you send me simulation file of LT spice for temperature range -5degC to 35degC.
Pl explain how did you plot this graph in LT spice and How do you calculate temperature.
Thanks !!!
djsfantasi
Joined Apr 11, 2010
9,237
So at 1°C you want to measure to ±0.01°C? Seems unreasonably precise.
This is what he keeps repeating. If the actual temperature is 1°, then his circuit must return something in the range of 0.99° to 1.01°!
Which is ridiculous... Most components won’t be able to support that accuracy. Add the resistor accuracy to the supply accuracy to the op amp accuracy, and he’ll require component ratings which don’t exist.
Unless he means something else?:rolleyes:
38,797
If you are going to immerse it in the water, then you need one that's waterproof.
It's not as linear as the one I posted.
Anyway temperature accuracy is 1%.
You aren't listening and still don't get it.
1% of what?
If the temperature is zero, then based upon your definition, the accuracy would also be zero, which is nonsensical.
So how about 1% of the range (40°C) which would be 0.4°C?
38,797
See attached.
I plotted it as shown.
What do you not understand about that?
The output is determined by the gain of the circuit.
The bridge is biased at 1/2 the bridge voltage by R1 and R2.
The output is then (Vb/2)/(R3+Ru2) * Rt.
Calculating Rt from the output voltage by plugging into that equation, you can then determine the temperature that caused that value of Rt.
mishra87
Joined Jan 17, 2016
1,063
1% of what?
I beg a pardon , if there is gap in my understanding.
Temperature range: -5°C to +35°C
I realize that temperature accuracy is +/- 0.5degC and not 1%.
You people were correct.
Sorry again.
Could you post LT spice simulation file and explain how did you plot the graph.
Pl do simulation for -5degC to +35degC.
And calculation for temperature.
It will really help me.
Alec_t
Joined Sep 17, 2013
15,156
Where/what is this water whose temperature you want to measure? If it's turbulent or subject to rapid temperature fluctuations then an accuracy of even ±0.5° may not be achievable.
mishra87
Joined Jan 17, 2016
1,063
See attached.
What do you not understand about that.
Thanks for sharing simulation file.
Could you let me know which analysis you have done to get linear graph.
mishra87
Joined Jan 17, 2016
1,063
Where/what is this water whose temperature you want to measure? If it's turbulent or subject to rapid temperature fluctuations then an accuracy of even 1% of the temperature range (0.4°) may not be achievable.
I beg a pardon.
Accuracy is +/- 0.5degC not 1%.
I am really sorry . Actually misunderstood and later I realized.
Regards,
38,797
The output voltage is a linear function of resistance if the thermistor has a constant current through it.
The bridge circuit does that, since the current through the pot and R3 does not vary (there is a constant voltage across them), and the thermistor current has to equal that current to keep the bridge circuit balanced, so thus the output is a linear function of resistance.
Remember that, with negative feedback, an op amp will do whatever it can to keep the voltage across its two inputs very close to zero volts.
mishra87
Joined Jan 17, 2016
1,063
Its distilled water and carbonated water for which we have to measure temperature.
example : Hot and Cold Electric Water Cooler
So assume you have to measure temperature of cold water and based om temperature you take your decision for refrigeration.
What is achievable accuracy in your opinion.
Regards,
mishra87
Joined Jan 17, 2016
1,063
How does these values comes from. What is calculation for that.
What is the Opamp gain to measure -5 degC to 35degC
Thank you so much.
This forum helped me a lot whenever I got stuck.
Regards,
