ThanksI think they are talking about the P & N of the chip. Opposite of the big FETs.
Here is a good calculator for the coil.
http://www.daycounter.com/Calculators/Air-Core-Inductor-Calculator.phtml
You may need more than a 100 volt fet. When at resonance the voltage can be pretty high.
What you have done here is, you named the difficult part of designing with those transistors. You want to throw 80 amps through 1 mm? You better know how to do it!80A and 600W power dissipation but they are the TO-247 package and have itty bitty legs (1mm). Are these ok with these currents with a heatsink and big tracks?
Lol this is exactly it I just can't get my head round that. 80Amps through that small a cross sectional area, its crazy! Gonna have to research how to mount these, might be some reference somewhere I hope.What you have done here is, you named the difficult part of designing with those transistors. You want to throw 80 amps through 1 mm? You better know how to do it!
I can easily imagine a solder joint that cracked because of heat cycling, developing half an ohm, and bursting into flame when an 80 amp pulse hits it.
I'm not sure what your goals are and I just hate to rain on a parade - but I will.
As far as the heat goes you can calculate it from the data sheet.
Using your IRFB4710 as an example:
It's on resistance is .014 ohms and at 40 amps is about 22 watts in the FET.
So if you go to the thermal characteristics it will show that from the junction to case is .74 C per watt and case to heat sink is .5 C per watt.
So if you had a perfect heat sink that kept the temperature at 25 C the junction would be about 52C.
If you have a good sized heat sink it might rise 2C per watt, so another 44C - for about 97 C.
The absolute maximum is 150C, so it's pushing it, but it will work there. The heat sink will be hot enough to hurt.
Most of the bond wires will do 60 amps - more for a short time. They are amazing little guys.
Have #12 check me out. He's the thermal guy.
The alleged power rating of a transistor has never worked for me. As far as I can tell, it's a fantasy number based on perfect conditions and designs that will barely survive the warranty period.
You want heatsinks? Try thermalloy.com or Wakefield
A lot of vendors sell heatsinks according to C/W specifications. If they don't, don't buy a specless product.
Ronv put you on the right track. It's all about the watts that the transistor suffers times the thermal resistance to the outside world. If you get a negative number, you broke a rule.
22Watts causing a 75 degree C rise in temperature is 75C/22W and that is 3.4 C/w as the maximum sum of all thermal resistances. Theta JC is .74 and the greased interface to the heatsink is 0.5 so you have 2.17 C/W leftover for the heatsink. Everybody with good sense would buy a better heatsink than that because we don't want our transistors able to boil water.
I read that as 400 FPM needed. The numbers on the right aren't aligned properly.
Besides, it's a waste of time to specify parts for one transistor when you have to cool 4 of them.
Besides, the amps you are using is only part of the story. The time it takes for the mosfet to turn on and turn off is a major contributor. It is only good that you got some practice in on this example.
I'd be swarming on the math, but how many amps and how fast and what is the duty cycle and how good are the gate drivers, and the integral of rise time and current flow and so forth aren't clear to me. Bottom line is, you do the heatsink last.
