No pull up or pull down resistor can compare to the speed of a Gate Driver, so they don't need the resistors.
K thanks I'll remove them then. One problem I have encountered though is I need pin 2 on the driver to be pulled down by the activation of optos 1 and 3 (descending) thereby activating the P-channels. In this configuration it isn't achieving that in sim. I know the sim isn't exactly accurate but it continues to show no voltage change at pin 2 when the corresponding opto is activated. It isn't a library component and pin potentials aren't changing at all with opto activation (p or n channel control) so I do think I can rely on the simulation at all after the AND gates.
NOTE on the first driver pins 3 and 4 are not supposed to be joined that's an error
