Hi there, I'm new here and have enjoyed reading a lot of the previous successes in fixing wine coolers. I got this one for free and so have nothing to lose in trying to fix it so here goes:
It is a HomCom 800-057, the PCB is marked Hanny HYS5A60-JH & PCB160706F2. It physically looks a lot like the Twin Star HYS60-12-KD - Control Board PCB111122K6 image on this thread: https://forum.allaboutcircuits.com/threads/how-to-repair-a-thermoelectric-wine-cooler.176296/ shown below, this isn't my board but looks very similar. It also looks like https://ambientstores.com/whynter-wc-16-wc-28s-pcb-part-black-display-panel/
This is my board, a Hanny HYS5A60-JH & PCB160706F2:
I
So after reading all the advice, I have replaced all the electrolytic capacitors and the fault remains the same which is:
1. When connected up as I received it, it displays HH on the front door display and beeps around every second and runs and cools, I can attempt to change the temp. but it returns to HH, beeping etc even after am extended period of time. The light works etc.
2. If I disconnect the front panel (the 3 pin connector, only 2 wired) CN5 I lose the front panel obviously, but it runs and cools.
3. The current NTC tests around 33 kOhms at room temperature.
4. If I swap in a 10 Ohm NTC, that reads around 11 Ohms at room temperature, the display then displays LL on the front door display and beeps around every second but runs and cools.
I can't rule out that it wasn't connected up correctly at the factory as this was a new unit so currently from top to bottom:
CN2 - CON - Not connected
CN5 LED FAN - Goes to display
CN4 FAN - Goes to Cooler Fan
CN3 FAN - Goes to Cooler Fan
CN1 NTC - Goes to the Thermistor buried somewhere inside the unit that seems impossible to get to.
Is there anything I could try before I resort to chancing my arm with Aliexpress, the website does not fill me with confidence and this isn't a direct replacement so it's taking a chance.
https://www.aliexpress.com/item/1005003192923444.html?spm=a2g0o.cart.0.0.566b38daewSpnW&mp=1
All advice appreciated and I'm enjoying about how these things work from those that have blazed the trail.
I
