Another one on plumbing...
Externet
Joined Nov 29, 2005
2,676
Hi. A faucet that features only shower and no tub spout. Can the tub spout be added by paralleling a 'T' at the upper shower branch and a tub spout with a stopper at bottom ?
38,784
I see no reason you can't using a pipe T.
The water will flow to the tube with the spout open, and to the shower with the spout closed.
Put the T as close to the spout as you can with a large pipe to the spout.
ronsimpson
Joined Oct 7, 2019
4,806
In my house the valve has a yellow pipe going down that is the same as the yellow pipe going up.
If you do not have the pipe going down you should be able to add a "T" and go to the tub.
Reloadron
Joined Jan 15, 2015
7,937
You can buy a bathtub spout with a diverter. Then it's a matter of running the diverted water supply up to a shower head and they make fixtures for that. Electrical we have the NEC Codes, no clue if your location has plumbing codes. :) Anyway, yes to answer your question with the right hardware. Things look a little like this, only pretty.
Ron
Reloadron
Joined Jan 15, 2015
7,937
Typical shower valve. Left & Right is to the water supply. (hot & cold). Up and down are outlets, and are the same.
We have a better image than I came up with. :)
Ron
Yes and for temperature control. Two inlets, one hot and one cold. One outlet for the mix. Next route the mix to either the shower head or the bathtub spout. I showed images but I don't have a blend valve but rather separate hot and cold. What part are you not quite understanding? The answer to your initial post is a yes.
Ron
