Non Linear Second ODE
22,116
I don't understand how dV/dt = Z/V
There are no general methods you can use to find a solution in closed form. Not only is the equation non-linear it is also time dependent. You might be able to separate the variables, find a differential form, or an integrating factor. None of those things is certain.
