Non inverting op amp scale and offset
Andrius Slizys
Joined Jul 20, 2019
12
Hey people!
The problem is simple: sensor is sending voltages ranging +1.6V to +10V but other device has to read it as 0V to +10V
I've learned that op amp is perfect to make a little converter.
I managed to use TLV2371IP op amp (non inverting setup) to scale voltage. Now I've got range +1.6V / +10V at input and +2V / +12V at the output.
I use 0 / +12 to the rails
I wasn't smart enough to get offset so my range at output would become 0 / +10.
So I hope people smarter than me could help me? I've googled and tried many circuits out there, but non of them work out.
38,854
Below is the LTspice simulation of one approach:
The output (Yellow trace) goes form 62mV to 10.1V for an input (Green trace) of 1.6V to 10V.
