Yes, I put the remote underneath the steering column and was able to activate the gate. Good stuff!With those types of transmitters simple single piece of wire will work rather well as an antenna although given the largely plastic and composite materials that a vehicle dash is made of the odds are it won't need one anyway. Especially so if you are only needing to transmit a few tens of feet at best.
Looking good after a few tries. The test is how long it can last before it hangs like before. I've put in spare holes to mount the TVS if needed as I couldn't get hold of it in time before I boxed it up.Your welcome on the remote recovery.
In any event, you can probably take a piece of Coax like RG174 and expose the end (remove the shield only), but try it with no wire first.
I eventually mounted a 1000uF cap because it's smaller but could you help explain why limit it to 220-470uF? Is it to prevent too high a discharge current to the remote and is the discharge current dependent on the impedance of the remote? The remote is drawing approx. 17mA.Basically, yes but I have to say that I do not like switching the power like that.
I agree with tcmtech about adding a capacitor across the zener but would limit it to 220 - 470uF and best to use a 25V or more electrolytic.
Graham
Glad it is working for you.I eventually mounted a 1000uF cap because it's smaller but could you help explain why limit it to 220-470uF? ...
I also wired it to the accessory instead of straight to the battery feed. If I wired it direct, apart from parasitic drain, are there are issues? ....
