New to solder headers for adafruit audio fx board, tutorial sought
ThirtyWest
Joined Jul 15, 2017
150
I have the little audio fx board from adafruit. I'd like to make it's end of the job a little more permanent, leaving me the freedom to mix and match buttons and such on a bread board.
The pins are small. Can anyone provide a good place to start reading to learn about putting this sort of thing together? It came with the header pins in plastic that can be broken off to size. I'm also thinking my iron's tip is too large for this job.
https://www.adafruit.com/product/2133
There's a picture there against a US quarter to give it some scale.
dl324
Joined Mar 30, 2015
18,431
Board in question:
There's nothing particularly difficult about soldering pads that size. The difficulty will be if you ever need to remove something where the small pad size could be problematic, i.e. lift easily.
Just use a small tip on your iron, e.g. conical, and use good technique.
Regarding the "snap apart" headers. You'll probably have a better experience if you use a cutter. Wire cutters can sometimes be used, but cutters like this would be better:
ThirtyWest
Joined Jul 15, 2017
150
So would it be easier to solder pins to this and then just press into a breadboard or just solder this to its on perf board and then set that atop the bread board? I've got two different projects that need this fx board...trying to find a middle ground.
DC_Kid
Joined Feb 25, 2008
1,242
use header pins and turn it into a "shield", or vice-versa.
but yes, if you solder header pins with long side down, it presses into breadboard perfectly.
if you want the Fx to be motherboard and want to push on shields, the mail pins go onto the shield board (aka daughter card) and female header pins get soldered to the Fx board with female ends up.
the Adafruit forums has all this info
dl324
Joined Mar 30, 2015
18,431
It depends on how it will be used.
Male header pins soldered to the board would allow it to be plugged into a breadboard, but female stackable headers would allow it to be plugged into a breadboard and have the signals be available from the female headers.
ebeowulf17
Joined Aug 12, 2014
3,307
For flexibility in situations like this, I really like the stackable header. You get to keep all your options open.
philba
Joined Aug 17, 2017
959
I mostly use male pin headers on those kind of boards but you should verify if the board will fit in a solderless breadboard. There should be room on either side.
On breaking the "snappable" headers, I use 2 pairs of needle nose pliers on either side of the place I want to break them. Leave a little room (< 1/2 the spacing between pins) and then snap. Or lay the header flat and press a utility knife where you want the cut. The pieces will fly so I put fingers on either side.
philba
Joined Aug 17, 2017
959
28 header pins poking into a solderless breadboard will be pretty solid. It will take a reasonable amount of force to pry it out. Though, SBBs are not intended for a permanent set up. Some people do it and it works ok for them. But, SBBs have a habit of not being stable over the long run. Usually requires some fussing.
DC_Kid
Joined Feb 25, 2008
1,242
+1
i test on bboard and then move it to a perf board where i solder all the wires.
