New to double ldr
kiltro
Joined Oct 24, 2011
63
Hey there!
I'm looking at a circuit using a VTL5C4/2 , I've never used such thing
So from the datasheet while for a normal photoresistor we vary the resistance of that single resistor, here is like having a potentiometer?
I mean the resistance between pin 3 and 5 is always the same?
Or is like modulating 2 resistors that will have the same resistance anywhere on the curve?
Ya’akov
Joined Jan 27, 2019
10,252
What are you planning to use it for?
It is not like a pontentiometer because what would be the wiper on the pot is fixed and never moves, and the two LDRs vary in resistance with the light from the LED which means the resistance on 3 and 5 varies in proportion. It acts as a voltage divider which would be beneficial in some circuits.
Ian0
Joined Aug 7, 2020
13,156
Is there really a pin 4? There is in the diagram but not in the photo.
And don’t think of designing it into anything commercial. It contains cadmium, so is illegal under RoHS regulations.
(although it does contain rather less cadmium than there is arsenic in a red LED)
Ya’akov
Joined Jan 27, 2019
10,252
Pictured and mentioned in this. There are some application notes that mention the matching of the two elements but unfortunately no specific circuit examples. They mention that it can be “used as a voltage divider” and that’s as far as they go.
kiltro
Joined Oct 24, 2011
63
The picture is of the single one
Here it is in all it's beauty :p
There's also written "RoHS complliant" on their page
:rolleyes:
https://xvive.com/audio/product/vtl5c4-2/
DickCappels
Joined Aug 21, 2008
10,661
I once researched the use of cadmium, particularly with Cd:S cells in mind and apparently small amounts of it are ok. Just don't lick the photoresistor :)
