New "Gizmo" Generator
Status
Not open for further replies.
roylong2017
Joined Feb 21, 2017
9
I have a solid state "gizmo" that is producing 2.250 volts DC and is lighting (dimly) a LED. But the unit is "floating" on a rechargeable battery. (It's been running for months under a Faraday Cage) See attached diagram.
The LED goes out when I try to remove the battery.
I calculate that the gizmo is producing 4.5 milliwatts based on the voltage x .002 amps minimum to keep the LED lit.
Question: What size capacitor do I need to replace the battery?
Thanks!
MrSalts
Joined Apr 2, 2020
2,767
Thanks!
How long will the capacitor be in place to substitute the battery.
Are you sure about 2mA? On some LEDs, I can see the P/N junction glow all the way down to 100 microamps - and less.
roylong2017
Joined Feb 21, 2017
9
Thanks for your response. The capacitor would conceivably replace the battery for good. The LED I have had a label of being .18 watts at 9v. My research, however limited, led me to believe that the LED goes out below 2 milliamps.
Papabravo
Joined Feb 24, 2006
22,082
What makes you think a capacitor can replace a battery? They have entirely different behaviors.
If the capacitor can replace the battery, why does the value matter?
AnalogKid
Joined Aug 1, 2013
12,128
How big is the battery you want to replace? Nominal voltage? Rating in A-h or mA-h? Chemistry? Is 2.25 V the battery output voltage?
Based on the trivially small amount of information we have so far, your battery capacity is around 5 A-h at some unknown voltage. Without the voltage, we cannot determine the total energy in W-h. Without that, we cannot calculate the equivalent capacitor size. Hint: it is very large.
ak
AnalogKid
Joined Aug 1, 2013
12,128
9 V x 2 mA = 18 mW, not 180 mW. Something is off by a factor of 10.
Or are you saying that the normal LED current is 20 mA?
ak
MrSalts
Joined Apr 2, 2020
2,767
Let me put a fine point on my inquiry: is this an “over unity” device?
No, it is likely a rectenna. A battery or capacitor (or possibly even a resistor) must work with the rectifying element (LED). The LED turns off when the battery is removed because the circuit is no longer a circuit - it becomes an open circuit.
roylong2017
Joined Feb 21, 2017
9
Thank you all for your responses. Yes. The "Gizmo" does have a capacitor in its internal circuit. So, I guess that's why it turns off when disconnected from the battery. Thank you for that. I was suspecting that.
This is new technology that I'm developing. The unit has been validated by a university in the UK. Soon to be tested for scalability.
Ya’akov
Joined Jan 27, 2019
10,235
You mean to tell me that a Gizmo Generator is not a well-defined and understood technical term. I'm positively mortified.
it does seem to be in the argot of the free energy crowd, though it does not seem to be well defined there, and I don’t think understood either.
ericgibbs
Joined Jan 29, 2010
21,441
Thread Closed
Restricted topics.
The following topics are considered "out of bounds" and will result in your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Devices designed to electrocute or shock another person
  • Jammers intended for actual use in other than legal academic contexts
  • Amateur/homemade rail guns and other high-energy projectile devices
Status
