New Batteries For EV's
cmartinez
Joined Jan 17, 2007
8,896
its amazing just how much batteries have changed since the first teslars and the future is only going to get better
A lot has also to do with the arrival of the white LED, and rare-earth magnets. It's those three techs that have made the current electric transportation (and power generation) revolution possible.
Just wait until fusion is finally mastered and room temperature superconductors become a reality ... now that is a revolution I'd like to see before leaving this world.
It's only 10 years away from demonstration, and maybe 100 after that for practical, useful engineering.
https://www.datacenterdynamics.com/...-for-good-after-south-korea-data-center-fire/
858TB of government data may be lost for good after South Korea data center fire
Destroyed drive wasn't backed up, officials say
Meanwhile, a government worker overseeing efforts to restore the data center has died after jumping from a building.
As reported by local media outlet The Dong-A Ilbo, the 56-year-old man was found in cardiac arrest near the central building at the government complex in Sejong City at 10.50am on Friday, October 3. He was taken to hospital, and died shortly afterwards.
The man was a senior officer in the Digital Government Innovation Office and had been overseeing work on the data center network. His mobile phone was found in the smoking area on the 15th floor of the government building.
https://www.chosun.com/english/national-en/2025/10/02/FPWGFSXMLNCFPIEGWKZF3BOQ3M/
The Ministry of Personnel Management, where all affiliated officials use the G-Drive, is particularly affected. A source from the Ministry of Personnel Management said, “It’s daunting as eight years’ worth of work materials have completely disappeared.”
It provided 30GB, gigabytes, per public official. At the time, the Ministry of the Interior and Safety also issued guidelines to each ministry stating, “All work materials should not be stored on office PCs but should be stored on the G-Drive.”
G as in GONE. What idiots, have they never heard of Petabyte tape backup systems?
https://magstor.com/products/magsto...75749&pr_ref_pid=8167066861733&pr_seq=uniform
Even if it was 858PB, backup is possible. TS4500 offers 2.63EB (exabytes)
https://www.ibm.com/products/ts4500
One of these guys with redundant fiber links to off-site backup centers is all they needed.
"If you think having a backup is too expensive, try not having one."
wayneh
Joined Sep 9, 2010
18,184
That's the way every corporate IT department works, and I never once complied. Oh I'd use the prescribed drive, but ALWAYS had a personal backup. I had projects and reports spanning decades and there was no damn way I was risking a life's work on the IT buffoons.
cmartinez
Joined Jan 17, 2007
8,896
1759964588140.png​
RE ? Renewable energy? Why?
End to end efficiency at low SOC is as bad or worst than Lead Acid, that's OK if you have lots of available energy to burn as wasted heat in your battery bank. LFP is 95 to 99% across the range. Linear voltage changes with SOC vs flat with LFP means energy tracking algorithms have lots of secondary corrections vs pure energy in/out as with LFP. And it's expensive vs LFP for what you get, today. You also need a special (vs LFP with drop in compatibility with LA), wide voltage range, sodium battery inverter to utilize the full energy range.
https://diysolarforum.com/threads/my-first-sodium-ion-battery.114938/
My general experience is that sodium cells are generally rated for higher C rates.
The problem is that you just cannot escape the voltage curve of the cells. The layered oxide based sodium cells have a roughly 2V dead to 4V full charge range. The poly-anion cells are even worse being roughly 1.5v to 4v. Add in a roughly 1:1 linear SoC to Voltage curve and they are just hard to use in traditional electronics.
A 15S poly-anion sodium battery would have a 22.5-60v operating range compared to 16s LFP which would be 40-58.4v when pushed to the edge.
drjohsmith
Joined Dec 13, 2021
1,680
we've been using sodium batteries for decades.. in the military..
they run at a few hundred C though. but have amazing shelf life and power density.
they typical have a squib or such to start them.
very popular in things like missiles,
