negative pwm to positive pwm
Alec_t
Joined Sep 17, 2013
15,156
i would like that the PWM will be on the positive.
Can I ask why? A PWM waveform can be 'inverted' by simply changing the duty cycle from x% to (100-x)%.
Do you have a schematic showing how/where this module is going to control the battery charger? I would expect the duty cycle to change automatically on the fly for control, but your module has buttons for manually changing the duty cycle.
Dodgydave
Joined Jun 22, 2012
11,395
It's a pre bought module with a pull up resistor to positive and open collector output, he wants a positive output with ground connection, so i suggested an external Mosfet or bjt, there is a % control on the module but i don't know if it's any use for him.
Mullins
Joined Dec 31, 2021
210
I have a battery charger for an electric vehicle. The battery charger need a pwm to charge the battery. the duty-cycle is needet in order to change the voltage. since the controller is missing I'm just trying to charge them with this circuit. Obviously I must stay there to supervise the voltage during the Charging time. I need to do this job once then the vehicle will be removed. But now I'm confused there's many solutions and I'm not able to chose. I was thinking it's was more easy.
BobTPH
Joined Jun 5, 2013
11,648
Are you sure? This sounds highly unlikely. Do you have any info about this device?
Mullins
Joined Dec 31, 2021
210
yes, you'r right. Anyway this is the only way to control this charger. So, please advice me which solutions is best for me?
