Need to boost microphone input to my audio tape recorder
sparky 1
Joined Nov 3, 2018
1,218
One of the phantom preamp, is a THAT 1510/1512 microphone op amp having same pinout as INA217
The schematic shown figure 5 for phantom, supply is specified or recommended for +/- 15V
THAT Corporation 1510/1512 Datasheet (mouser.com)
Some prefer +/- 18V supply pcb diy available
Mic Preamp Kit - Electronics DIY Projects PCB (fivefish.net)
If your goal is more basic you would eliminate some of the features.
It does not hurt to see the how and why of various components/ audio quality.
The op amp and circuit will either convert impedance and quality or will barely pass.
rameshdk12
Joined Aug 20, 2024
11
I changed the 6.7k resistor in second stage to a potentiometer in series with 1K which has improved the gain.
Coming to The schematic of SSM2019 preamplifier IC given with its datasheet, The circuit has input from a condenser mic(with phantom power of 48v) how can I adapt the circuit for a dynamic microphone? In a single stage will it provide high enough gain?
Is it better than LM4562?.
rameshdk12
Joined Aug 20, 2024
11
There is noise and hum in the 741 based circuit. Is it mandatory to go for another opamp?.
I could not get the required bypass capacitors of the value required at the power supply, but I am on it.
which filter capacitor values would I require at the input and possibly outputs of the preamp?
Thanks ,
Ramesh
bertus
Joined Apr 5, 2008
23,006
How is the preamp powered?
Is the microphone cable shielded?
Hum can come from the power supply or pickup from the microphone cable.
Bertus
LowQCab
Joined Nov 6, 2012
5,102
It's not "mandatory",
but it certainly can't help but to improve the performance of the Circuit in every respect.
Any 741 is just plain bad, all the time.
The "Noise and Hum" is likely from
Circuit-Layout, and/or, inadequate-Power-Supply-Filtering, and/or, Input-Shielding.
rameshdk12
Joined Aug 20, 2024
11
I am using a power supply based on 7809 and 7909 voltage regulator ic's with 1000uF electrolytic capacitors in parallel.The microphone cable looks to be shielded.
Regards,
Ramesh D.
bertus
Joined Apr 5, 2008
23,006
Do the two regulators have the recomended capacitors on the in and outputs?
Without these capacitors the regulators may become instable and create noise.
Bertus
LowQCab
Joined Nov 6, 2012
5,102
Do You have 100nF Ceramic-Capacitors Bypassing the Chip,
and, attached as closely to the Chip as physically possible ?
Don't bother looking at anything else until the above has been taken care of.
A ~47uF Electrolytic-Capacitor,
placed directly after a ~1000uF Electrolytic-Capacitor,
is a pair of wasted Components.
When You refer to a Capacitor, You should always state what TYPE it is.
Sometimes it's even important to provide a Spec-Sheet for the Capacitor.
Capacitors have particular Specifications,
and are designed for specific types of applications and Frequencies.
sparky 1
Joined Nov 3, 2018
1,218
Schematic to high end adjustable Mic preamp. The OPA2134 or LT1115 is an improvement 741
I would think this would exceed the tape recorder capability
