need help x12sl mosfet
sidsod
Joined Aug 31, 2017
I am new to this forum and i need some help with this mosfet ,X12SL MOSFET , 2D150C :(
i have been looking all over google looking for a replacement mosfet, but i cannot find any for sale unless i buy in bulk,:mad:
I hope this is the right forum for this question, can i use a different mosfet type (a more common one) that will work
the board number PS65R14VAI if that helps ..
MaxHeadRoom
Joined Jul 18, 2013
30,890
Evidently a Sauna board, what is the load it is switching, a element?
Shouldn't be at all critical.
The 2D number is a bridge rectifier.
Max.
sidsod
Joined Aug 31, 2017
hi
thanks for the quick reply ,
just to let everone know i am a newbie at Electronics :oops: ,
when i was testing the mosfit with a multimeter all i was reading was O,L on all 3 pins but i thought it was a standard
mosfet D,G,S , so sorry i dont know the load switching , its the only mosfet that was giving me strange reading.
thanks
38,953
I could not find any info on that MOSFET's characteristics (not even its polarity) and so we need to know something about what the MOSFET does before we can suggest a replacement.
sidsod
Joined Aug 31, 2017
sorry for the late reply provider problems. and thanks for the reply
i have no idea what the mosfet does:(, but what i do know is i have tested all the Capacitors and i have the correct voltage up to the mosfet and then nothing , here is a sites that i found the sells them if that helps https://www.transistorsmosfets.com/index.php?route=product/search&search=X12SL https://www.alibaba.com/trade/search?fsb=y&IndexArea=product_en&CatId=&SearchText=X12SL https://italian.alibaba.com/product-detail/-electronic-ICs-chips-X12SL-X12SL-60037205440.html sorry this one is in italian. i dont know if will help but i have put 2 pic in
Zbuilder
Joined May 1, 2018
I am having the same problem with sauna power supplies S-60-12 and S-60-12L. Yes 2 power supplies I've been thru with the exact same problem and same component X12SL. Has anyone found an equivalent replacement? It's a 125VAC to 12VDC 5A ouput that powers LED lights, 2 touchscreen control panels (membrane pushbutton type) radio and speakers. It worked for years and then pow. The 2nd power supply blew as soon as it was connectd and turned on so something on the 12V side is shorted. Fuse is ok on AC side.
