Hello Everyone
I am trying to eliminate all interference on a conservation project I am working on. It is using RCAOP Remote Controlled Aerial Observation Platforms (drones) to help stop poachers for a conservation group.
The problem is when I tried asking the rc forums i keep getting told that what I am asking about "is beyond the experience of a weekend hobbyist" So I am coming to a place that hopefully can help.
I need help understanding exactly what to do in order to shield servo wires, A/V wires, antenna wires, power wires, and carrier wires.
First I am planning to use this 18gauge shielded wire,
And this 26gauge wire each pair is individual strands, then twisted together, then each pair is shielded, then all four pairs are foil shielded and then braided in silver.
Challenge; to protect rc avionics from as much outside interference as possible to increase distances of flights.
Electrical setup; battery running avionics, electric motor and A/V transmitter, and receiver.
electrical circuit; Battery + and -, no chassis ground, Airframe is not metallic, it is of Styrofoam and balsa wood, ergo there is no earth either.
I need to know what needs to be (A) shielded, (B) ferrite rings, (C) filters, and (D) shunts. (E) twists
I know that the electric motors, batteries, autopilot, and the transmitters can cause noise worst being the motors, so how do you eliminate it?
1. Camera power wires
2. Camera signal wires
3. Audio video transmitter power cables
4. Audio video transmitter antenna cables
5. 433 antenna cables
6. 433 power cables
7. Auto pilot wires.
8. Servo wires and leads servo wire is 24-22ga
9. Wires to gps
10. Motor cables
11. ESC cables and wires
12. Battery cables
Please use the # and the letter to describe what is needed. Then tell me exactly what wire and where to put the items and how to do it.
Example 2, A,B Camera wires must be shielded individually, solder the center wire to the signal pin, + pin.... take the shield wire and solder together one end that plugs into the OSD.... a Ferrite coil should be added XXXX from the camera.....
Task 1 how do you shield servo wires
There seems some debate on how to shield the servo wires, some people say that each wire, the positive, negative, and the ppm signal wire should be 3 separate wires ran from the servo to the receiver, with each wire having its own individual braided shielding, with the shielding twisted and soldered together and grounded to the - of the receiver leaving the shielding un soldered on the servo end.
others say that you need only 2 wires, + at the center of one cable and the ppm at the center of the other cable, using the shielding as the ground, soldering the shield wire to the negative lead of the servo and to the negative pin of the receiver.
So what is the correct way to shield the items.
6. 433 power cables
9. Wires to gps
10. Motor cables
12. Battery cables
