need help with bulding a DCDC Buck Circuit (multi output)
david1234
Joined Nov 27, 2013
104
Hello ,
I have a project that I wnat to build for him a DCDC back circuit
right now I use 4 XL405 DC-DC , but I want to create my own circuit (this is for a small project I have and I will create ~ 100 of it)
the input 24-35V
the 4 output voltage are:
12V 2A
24V 2A
5V 4A
3.3V 1A
I don't use so much power I took around 50% more then I need ,just to be sure
I need it to be protected from over voltage & current
also if something will stop working it will not affect the other output
how do I start , which IC I need for it ?
Thanks ,
david1234
Joined Nov 27, 2013
104
I know this tupr of DCDC Buck
but I want to creae my own DCDC - that way I can build the PCB as I want
and also add some protaction to it?
