Need help with a dfr0494 (raspberry pi ups hat)
cinder
Joined Mar 10, 2023
Hello everyone
Just got a dfr0494 (uninterruptible power supply) for a (I think this is correct) sc0195 (raspberry pi mini computer), and I think everything is working except the battery I got for it.
Just to clarify the rpi is working fine, the power supply for the dfr0494 seems to be working correctly, the battery I got for the dfr0494 is draining while charging.
Here’s the wiki (which contains the specifications) for the dfr0494:
https://wiki.dfrobot.com/Raspberry_Pi_UPS_HAT_SKU_DFR0494
Here’s the power supply I got for it:
https://www.amazon.com/Raspberry-Supply-SoulBay-Adapter-Android/dp/B07CVH21NC
And here’s the battery I got for it:
https://www.amazon.com/Battery-Packs-Lithium-Polymer-1200mAh/dp/B00J2QET64
Any help is greatly appreciated!
Does the battery charge if the raspberry pi is off? You have a 3A power supply, it might be inadequate to both charge the battery and power the computer. What's the normal current draw to the RPi when operating normally?
