I'm new here, so this is also my little intro. I don't know much about circuits, and until recently, my only experience with circuits was ripping apart old RC cars and amping the voltage to make them faster and building new ones from old pieces. I started doing some reading on the site's textbook and actually started doing somethings that are practical with circuits.
What I would like to do, is create a high speed LED flash that I can use for some high speed photography. I'm shooting for a sub 20 μs flash. At the moment I'm merely trying to make a proof of concept circuit with 1 LED. Eventually the problem is going to be not enough light, but for now I want the timing right. Once I get the timing circuit I can add more more power and LEDs to the circuit.
Please bare with me, as I am just beginning to learn most of this.
The .pdf below is the circuit that I have come up with for my purposes so far. My circuit is derived from this example I saw, with R2 and C1 as the time controlling components for the 555 IC.
I have a very rudimentary understanding of many of the components I used, which should become obvious as I explain.
The 3.5mm jack supplies a 5v current from the middle of the jack when I want to activate the circuit.
The LEDs I plan to use at the moment require 350mA, hence the transistor that controls the power supply to the LED.
Please ask as many questions about my circuit, I made it fairly quick and I feel like there are many mistakes, so point them out if you see them.
The question I really need answered is will this work and if not how can I make it.
