Need help understanding triggering and time delay
Vman94
Joined Mar 11, 2019
6
My group at school had to design a 3 controller system with time delay, we have 3 LEDs the red LED turns on immediately, Green LED 2 turns on 2 seconds after the red LED turns on, and the yellow LED 3 turns on 3 seconds after the Red LED, the multisim diagram is attached and we confirmed on the breadboard it works, we have two resistors in series and it feeds the negative input of the LM324N, my question is how does voltage divider rule trigger time delay into the LM324N?
38,884
If you can write the equations for what determines the time delay for each stage, you can answer that question.
Hint: It involves a charging RC time-constant and the trigger level of each comparator.
LesJones
Joined Jan 8, 2017
4,544
I don't understand how you designed it if you don't know the operating principal. Is this a question set by your teacher ?
Les.
