Need Help: Looking if anyone knows the brand name of this component
28,492
Could the name be Siemens?? They make lots of industrial electrical stuff. Probably if you dismount that switch assembly you will even find a model number.
28,492
Once again, if you remove the assembly from the panel it will be possible to get a good view of the text molded onto the housing. the view we have is poor in that there are reflections and obstructions. Do you need to get repair parts, or just more of the same product?
OK, the switch that we see behind it may be a different part, BUT it looks like the same brand. Thus looking at it can reveal something.
What sort of piece of equipment is this, anyway??
28,492
Is the goal to locate a replacement for a failed part? Or is there some other purpose? for that matter, I have been assuming that the part in question is the one with the two exposed terminals. That may be the same brand as the panel mounted switch next to it. In addition, there may be a more legible brand mark on the other side. While the photo is fairly clear, it leaves a lot not shown. Also, knowing the country of origin of that piece of equipment can help suggest possible brands. There is a lot of knowledge and insight available in this forum but not much in the line of mind reading. We all need background to be able to deliver the most useful answers. That applies to most of the posts.
