Need help in Aptitude Question
33,155
How to solve this?
If this is the approach that you are going to always take, namely give up and ask how to solve it, then stop wasting your time, money, and effort pursuing a technical education. The reason is quite simple -- anyone that receives a technical education is doing so in preparation for a career of solving problems! That becomes the value that you bring to the table and that you expect others to pay you for -- being able to solve their problems for them. You can't succeed at that unless you can actually solve problems without having to always ask someone to show you how to do it!
33,155
OK,
Rpq=1+1+1
Rp'q'=1ohm+1//Req + 1ohm
something like this
Yes, something like that, except that Rpq is not 1 Ω + 1 Ω +1 Ω (and I am once again getting tired of having to tell you repeatedly to track your units. 1+1+1 is a number, it is not a resistance).
Rpq is not just the resistance of the three resistors that we split off. Rpq IS the same resistance as Rp'q'.
So work with
Rp'q' = 1 Ω + (1 Ω || Req) + 1 Ω
Now apply the formula for combining two resistors in parallel.
Then adjust the equation to account for the fact that Rp'q' is, in fact, equal to Req.
RRITESH KAKKAR
Joined Jun 29, 2010
2,829
Rp'q'= 1ohm + 1ohm || (Req) +1ohm
Rp'q'= 1ohm x 1ohm || (Req=R1xR2/R1+R2) +1ohm
Rp'q'= 1ohm x 1ohm || .75ohm +1ohm
R1=3 ohm
R2=1 ohm
Req=R1xR2/R1+R2
Req= 3/4=.75ohm
@RRITESH KAKKAR
Note that the symbol || is 'short hand' for "in parallel with"
Hence:
Rp'q' = "1 Ω + (1 Ω || Req) + 1 Ω"
means:
Rp'q' = 1Ω in series with (1Ω in parallel with Req) in series with
Do not confuse || with absolute value notation wherein the vertical lines bound an argument e.g. |x|
Got it?:)
So work with
@RRITESH KAKKAR
FWIW here's the same advice stated otherwise:
IF the first stage was actually disconnected from the semi-infinite network then Rpq = 3Ω and Rp'q'=the network resistance.
However the first stage is connected to the semi-infinite network so Rpq=Rp'q'= the network resistance.
The key to the solution is vested in the fact that the network resistance is the same despite the presence or absence of the first stage (and, for that matter, any finite number of preceding stages).
So: Let the network resistance ='R'
2Ω in series with (1Ω in parallel with R) = R
------ All you need do is express the forgoing algebraically, solve the resulting second degree equation for 'R', discern the applicable root and you've got it!:cool::cool:
BTW -- Kudos on your eschewal of recourse to analysis! -- Your discipline in that regard is truly inspiring!!! :):):)
Sincerely
HP:)
33,155
Ω
how insert this sign?
If you have a keyboard with a number pad you can hold down the Alt button and type 2, 3, 4 (written as Alt-234). This only works with a numeric keypad (at least that's been my experience).
You can also click the button with the "S" on the far right of the edit window tool bar and select the symbol you want. This will paste it into the top left corner of the edit window (not at the insertion point, which is very annoying) where you can cut and paste it to where ever you want.
33,155
1) Click on the large, bolded "S" on the format bar -- This will display a 'ribbon' of symbols below the text entry box.
2) Click the Ω symbol on said ribbon -- this will insert the symbol at the cursor's position in the text entry box.
Best regards
HP
Does it insert the symbol at the cursor position for you? It used to (before the switch from vBulletin), but now (for me) it always inserts it as the first character in the text window and I have to move it manually.
33,155
R1=3 ohm
R2=1 ohm
Req=R1xR2/R1+R2
Req= 3/4=.75ohm
You are STILL insisting on using values that you KNOW are WRONG!
Forget this damn 3 Ω. You KNOW that if the total resistance were three ohms, then that would mean that the total resistance is 2.75 Ω and since you know it can't be both 3 Ω and 2.75 Ω then you KNOW that it is NOT equal to 3 Ω. So STOP using 3 Ω !!!!
Req is an unknown! It IS the value that you are trying to solve for!
Rp'q' is also unknown, but you know that it is ALSO equal to the value that you are trying to solve for!
What is (1 Ω) in parallel with (Req)? Remember, Req is an unknown, so it needs to stay as Req in your equation.
FWIW -- In my case symbols are placed at the cursor despite user interface style or method of character selection:confused: -- perhaps said behaviour varies with local display settings?
Best regards
HP
Aleph(0)
Joined Mar 14, 2015
597
HP why not allow convergence tests? I say you are being the wet blanket to always insist on math being done the hard way:p! I know the problem has easy algebra solution but that's not point! I say why walk when can ride:)!
